i read an article(http://www.overclockers.com/articles511/) dealing with the physics of water cooling and is said that to get a better heat transferrance, you would need to create some turbulence...I was thinking that for increased turbulence, one could create a heatsink who's contents was hollow except for a small rotor/fan. I'm talking about a propeller that moves because the water would be forced inside the heatsink, by means of the inward flow, and be moved a little faster because of the water being moved out. Would this not work? i have posted this in the overclockers.com board too and i have also put a diagram there which could help. any insight or ideas would be welcome. Thanks. MnX4
Putting the laughter back in to Slaughter.
