i am trying to install half-life + counter-strike on my computer.. i can install half life but when i try to install the patch for half life (i have all the patches including full file which is over 100mb) it keeps giving me the error about language.. but i know both the patch and the half life is in the same language.. i dont exactly remember the error message cos i had enough of it and uninstalled half-life .. i was something like anyways i installed it again the message is exactly life this " You are attempting to install a half-life update that is the incorrect language version. You are currently runing the Non-Violent english version of half-life this verion is for the english version of half life. installation will now exit" i hate this thing where can i find the non-violent half life patch ??? or how can i get over this problem ... any help ...????
Non-violent??? in Half-Life I would check and MAKE ABSOLUTELY cetain that the Content-Control is NOT enabled or you won't be abled to multiplay AT ALL with HL or any MODS.
My OS features preemptive multitasking, a fully interactive command line, & support for 640K of RAM!
Okay. Under Half-Life go to the "configuration" menu. After that, proceed to the "Content control" option which should be the 4th option under the "configuration" menu. Next Uncheck the "Activate content control" option. To put it in more simple terms:
1. Open Half-Life
2. Go to "Configuration" menu
3. Go to "Content control" menu
4. Uncheck "Activate content control"
Tell me if that does the trick, ok?
Actually JM, you got it backwards. I was thinking he might already have the gore off. Muliplayer games don't work if Content control is activated. In other words, If he CAN'T see gore, then he CAN'T play online Counterstrike or Half-Life games.
