Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem printing to shared printer from programs
Forum Windows XP : Windows XP General Discussion - Problem printing to shared printer from programs
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I am having a problem with a Panasonic KX-P7100 printer attached to a
Windows XP machine. The printer works fine on the PC it is attached
to but when I try to print to it from another PC I have issues.
Basically what happens is that I can setup the printer on the remote
PC and I can print a test page no problem but I can't print from any
programs (like Word or Excel).
I have tried the following to resolve:
1. Re-installed printer on attached PC.
2. Re-created printer on remote PC.
3. Checked event logs on both PC's to check for issues. None.
4. Made sure both PC's had the same patch level. All patches were
installed (including XP SP2 and the GDI+ Update).
5. Turned off Internet Connection Firewall for both PC's
Nothing seems to have helped. When I send the print job and watch the
queue (from the remote PC) it just prints normally. Problem is it
never shows up. Any help would be appreciated.
Tanks,
F
Sponsored Links
Did you make sure that "File and Print Sharing" was enabled.
> Tanks,
> F
Reply to Anonymous
Yes I did. This printer actually worked fine like this for a while.
I assume it has something to do with SP2 or the GDI update but I am
not sure.
Thanks,
F
"Thomasgw" <Thomasgw@discussions.microsoft.com> wrote in message news:<D522CEC0-52D5-479E-BBF3-343129B23461@microsoft.com>...
> > Tanks,
> > F
Reply to Anonymous
There are 912 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
