Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Print Spooler always running 100%
Forum Windows XP : Windows XP General Discussion - Print Spooler always running 100%
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have XP/SP2 Home ed. with an Epson 780 inkjet. When I tried to connect a
new laptop (Same OS) to the wireless network to share the printer, the
spooler now runs 95+% of the CPU.
I've attempted to uninstall all print drivers and epson monitors, the print
service continues to hog the CPU. Any thoughts??
Sponsored Links
Uninstall and reinstall corrrectly...
http://www.coribright.com/Windows/Article%20One.htm
Cari (MS-MVP) Windows Client - Printing/Imaging and Hardware
www.coribright.com
"RI_Updates" <RIUpdates@discussions.microsoft.com> wrote in message
news:CB311414-1E16-477B-81B9-36F11F0FFBCD@microsoft.com...
> print
Reply to Anonymous
Hi,
I would advise a manaul removal of the printers from the registry. Please
see steps below:
Steps:
1. Click Start, click Run, type regedit and click OK.
2. Delete all the contents of the following registry keys:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Environments\WindowsNT x86\Drivers\Version-2
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Environments\WindowsNT x86\Drivers\Version-3
• HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Printers
3. Check the following registry key for third-party monitors. Remove any
non-default monitors:
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
ï?¶ The default port monitors are:
AppleTalk Printing Devices (When Services for Macintosh is installed)
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT Fax Monitor
4. Check the following registry key for third-party print providers. Remove
any non-default print providers:
• HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers
ï?¶ The default print providers are:
Internet Print Provider
LanMan Print Provider
5. Delete the printer driver files:
• Delete all drivers from the
%SystemRoot%\System32\Spool\Drivers\W32x86 folder.
6. Restart Windows.
7. Re-install the printer drivers.
8. Test to see if you are able to print.
Regards,
Reply to Anonymous
There are 601 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
