Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Pro's and Con's of Water Cooling????
Forum Overclocking : Cooler and Heatsinks - Pro's and Con's of Water Cooling????
Thinking about getting a Water Cooling system, but don't know anything about them, from what i see in Pictures, it looks like it makes your Ability to work on your PC Annoying..
Thanks/Rob
Once you go AMD, You never Go back!!
Sponsored Links
well one pro are that it keeps your cpu cooler than most conventional hsf's so it owuld make it pretty easy to keep your cpu stable, specially when overclocking. A couple of cons are the fact that the system could leak and it usually cost's a lot. However, if you're careful, you'll have a very stable and cool system running.
Putting the laughter back in to Slaughter.
Reply to Mnx4
depends on the setup you have, I have plenty of room in mine still, but its not portable <A HREF="http://www.calvsplace.cwc.net" target="_new">link here</A>
If they squeeze olives to get olive oil, how do they get baby oil?
Reply to CALV
Alright, Thanks for your response, i think i'll go with the Volcano 7 for now, I don't think im ready for overclocking yet.. I heard the Volcano 7 is pretty big, but i also heard its a pretty good CPU fan.. would this keep the Anthlon XP 2000+ at the right temperature, Would you recomend a Second case fan..
Thanks/Rob
Reply to Rob423
You can get an XP 2000+ system from gateway or someone like that with a crappy fan that'll keep it at a decent temperature. A Volcano will do more than fine. It'll even be good for some mild overclocking.
Lyrics. Wasted time between solos.
Reply to silverpig
what do you mean MILD!!!, it's a huge HSF 7,000rpm...he should be sufficient for more then mild i would assume...if not then what do you recommend other then water cooling system
rob,
Reply to Rob423
i suppose it depends on your definition of mild but i would say fan based cooling will always allow mild overclocking
to get hardcore overclocking you need water !
or you could try peltier+fan which can work
remeber overclocking means running a system stable, not just booting up and running long enough to take a screenshot b4 it crashes.
Trying is the first step to failure
Reply to Grifter
There are 1263 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
