Thanks Burger....is the Alpha better then the Volcano 7, or if i want to over clock the 2000+, would the Volcano6cu be good with the OC, or the Alpha can handle OC as well or no...
The Alpha is the BEST heatsink on the market, better than anything else. Also, it uses the four holes next to the socket, as opposed to a normal clip that goes on the lugs. That's much more sturdy. Check it out at <A HREF="http://www.newegg.com" target="_new">Newegg</A>
