Tom's Hardware > Forum > Overclocking > CPUs > challenging problem ! !
Forum Overclocking : CPUs - challenging problem ! !
HI,
I 've just built a new system , with an asus a7v266-e and amd athlon xp 2000+
Everything was fine , and the bios was showing me "AMD ATHLON (XP) 2000+
the only thing that concerned me it was that the cpu temperature was between 45 and 50 degrees C
so i decided to reinstall my fan/heatsink(swiftech) to check if the overheating was because of a bad installation.
So i take the cpu and i clean it from the artic silver (thermal compound) i use acetone on the cpu core and palmolive soap on the ceramic. I mostly removed all the compound , and all the l1,l2 l3 l4 bridges , seemed quite clean and free.
i reinstall the cpu and the heatsink and the drives and videocard. i start the machine but when i'm in the bios it only allows me to choose (the cpu frequency) between 1010Mz and 1466, and even if i choose 133.33 X 25.5 manually
the bios now it sees my 2000+ as a 1700+ ! ! ! (always core V 1.80)
What should i do ? (i tried to update the bios but no change.)and the system seems not stable as before.
sometimes when i turn it on it shows me Amd Athlon Xp 1900+
but then after a while that it's off and i turn it on , again it says AMd xp 1700+
What should i do ?
did i , in some way break the cpu ? or shorted one of the bridges with the compound ? so the multiplier it's not stable ?
how could i fix it ?
Help!
Sponsored Links
Well, acetone was fine but I doubt using soap on the bridges, tends to get stuck between the grooves. And clean tap water does tend to corrode fine metal stubs that the bridges are!
I cant imagine BIOS not letting you use any FSB, it isnt really under the CPU's control. you can force the BIOS to set a certain FSB, 133.3 MHz should be just fine. As for the multipliers, cleaning the bridges (all of them) has had some effect on it. Thats why I would suggest you to clean all the bridges with acetone and unlock the L1 bridge, maybe that would set the bridges right.
BTW your XP2000+ works at a physical frequency of 1.67 GHz, that is (133 x 12.5) try setting the multiplier to 12.5
girish
<font color=red>Nothing is fool-proof. Fools are Ingenious!</font color=red>
Reply to girish
Hey thanks for your interest, ill clean the bridges with the acetone.
i tried to set (133.33 X12.5) but it always say (at the boot) 1700+
anyway i'll try to do what you said.
thanks
Reply to Anonymous
Hi Girish or anybody out there,
You mean i have to clean those microholes ?
i'll try.
thats what you mean by unlocking the l1 brdge ?
Reply to Anonymous
Yes you need to clean as well as possible but only use Acetone or 99% alcohol, then
let it dry throughly before reinstalling.
º :smile: º <font color=blue>You get what you pay for. :smile: All advice here is free.</font color=blue> :wink:
Reply to OldBear
There are 1168 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
