Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Thanks. I tried and I still only get bitmap type option.
Is there any other reason?
Pierre
"Carey Frisch [MVP]" <cnfrisch@nospamgmail.com> wrote in message
news:enPbwji2EHA.208@TK2MSFTNGP12.phx.gbl...
> Go to Start > Run and type: CLEANMGR.EXE , and hit enter.
> This will start your disk cleanup utility. Make sure to cleanup
> your Temporary Internet Files.
> Internet Explorer Saves Images As Bitmaps (.bmp Files)
> http://support.microsoft.com/defau [...] duct=ie600 >
> Internet Explorer Does Not Save Graphics Files in the Proper Format
> Carey Frisch
> Microsoft MVP
> Windows XP - Shell/User
> Be Smart! Protect Your PC!
> http://www.microsoft.com/athome/se [...] fault.aspx >
> "Pierre Vachon" wrote:
> | Why is it that when I try to save a photo off the net it only gives me
> the
> | option as a bitmap. I scroll the file type menu and there is only bitmap
> in
> | there.
> | Thanks in advance for the help
> | Pierre
Hal
Hal Hostetler, CPBE -- hhh@kvoa.com
Senior Engineer/MIS -- MS MVP-S/U -- WA7BGX
http://www.kvoa.com -- "When News breaks, we fix it!"
KVOA Television, Tucson, AZ. NBC Channel 4
Still Cadillacin' - www.badnewsbluesband.com
"Pierre Vachon" <vachonpierre@sympatico.ca> wrote in message
news:u6xtd.32566$dC3.752930@news20.bellglobal.com...
> Pierre
http://support.microsoft.com/defau [...] duct=ie600 > >
> > Carey Frisch
> > Microsoft MVP
> > http://www.microsoft.com/athome/se [...] fault.aspx > >
> > the
bitmap
> > in
> > | there.
> > | Pierre
