SWEEZUS...where do you live?
my rheostat was like 3 bucks, and it is a 3 watt 25ohm rheostat.
and a 120mm panaflow..the local electronics shops dont even have those..
lol
i think that FRYs has 120mm sunons, but those are like 12-15 bucks EACH.
oh, and usually a rheostat has 3 leads....the middle one is the input, and the outer two are the ones that change.
depending on which way you want the knob to turn to control the speed, you hook it up to the different prongs.
for example, i have mine hooked up so that when i turn the knob clockwise, it lowers the resistance, and speeds up the fan.
to do this, looking from the knob side of the rheostat, i hooked the lead into the center prong, and then the output lead to the right prong...then i covered the other prong with heatshrink so that it wont short to anything.
all the connections i covered with either heatshrink or electrical tape (where i couldnt use heatshrink)
sorry about the k thing...but i have talked to people who dont know that k stands for thousand...so..hehe...i usually try to put it in there, even if you might know it, because then if someone else is reading, that doesnt, then they will know....
-DAvid
-Live, Learn, then build your own computer!-
