Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have installed a HP1350 on a standalone PC with WinXP Sp2; Gigabyte 8SQ800
M/B; SiS655 chipset; and 57GB free on the HDD.
Always the system says "Error connecting to scanner" when ever trying to
scan. The printer works fine.
I have: un-installed and re-installed the software +8 times; deleted the USB
devices in Device Manager: upgraded the chipset to F7 and updated the USB
drivers; switched to the generic USB drivers; tried Win2000 compatibility
mode; did a system restore to prior to SP2.
All to on effect. I think it might be a registry problem and need help with
where to look.
Did it ever work?
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"CharlesF" <CharlesF@discussions.microsoft.com> wrote in message
news:05FE6273-7490-4F25-88F4-33D0A553D0B7@microsoft.com...
>8SQ800
> USB
> with
> where to look.
No, it never worked on my system, but both printer and cable work on another
machine.
"Cari (MS-MVP)" wrote:
> Did it ever work?
> www.coribright.com >
> >8SQ800
> > USB
> > with
> > where to look.
have the same problem on a hp psc 1310 all -in-one , did you resolve the
problem
> where to look.
I have the same problem ,have you reslove the problem?
> Did it ever work?
> >8SQ800
> > USB
> > with
> > where to look.
Hi,
I backed-up, re-formatted and reloaded everything. Turns out there was a
conflict when I was loading the HP software; this this it asked to restart
(which had never happened before) and after the restart, finished loading.
Because HP's software is a bit dodgy, it doesn't create a log file of the
installation so there is no way to identify the problem and their support is
not good.
