Problems with add new hardware installing printer
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I added 4 Hp 1320 printers to 4 computers and the software installed okay
with add new hardware option but now about every 30 seconds the mouse pointer
changes to an hour glass. I contacted Hp and they said that I had to install
the printer without the new hardware wizard but I can't get windows to not
run the add new hardware wizard it automatically installs the printer before
I have a chance to install it manually and it doesn't give me a chance to
cancel. Any input would be appreciated. It is very annoying.
twila
See:
http://www.coribright.com/windows/Article%20One.htm
Do NOT connect the printer to the PC until the software tells you to do so.
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"Twila" <Twila@discussions.microsoft.com> wrote in message
news:FC036501-886F-453D-AC5D-D4A096D626E6@microsoft.com...
> pointer
> install
> before
> twila
I tried that. Once I plug the usb cable into the computer when the software
asks for it I get a bubble down by the time saying that it found new hardware
and is installing it and by the time I am done with the cd install the bubble
says your new hardware has been installed and is ready to use.
"Cari (MS-MVP)" wrote:
> See:
> www.coribright.com
> > pointer
> > install
> > before
> > twila
That's how it should work!
www.coribright.com
news:F159E660-0F5E-437F-8788-EE982FC23067@microsoft.com...
>software
> hardware
> bubble
>> See:
>> so.
>> www.coribright.com
>> >okay
>> > pointer
>> > install
>> > not
>> > before
>> > to
>> > twila
Ask the community
