Printer problem 6161
Forum Windows XP : Windows XP General Discussion - Printer problem 6161
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
My printer Canon i450 worked normally. I had to change one ink cartridge.
Afterwards the tests printed normally. Now I get the following error . It`s
printing no more. What should I do ?? OS: Windows xp, with latest updates
including SP2(yes the printer worked normally after installing SP2) IE 6 and
Outlook express.
Thanks for your help Phil
>>>>Event Type: Error
Event Source: Print
Event Category: None
Event ID: 6161
Date: 12/15/2004
Time: 6:08:13 PM
User: VAN-C5NR89CXH6O\Owner
Computer: VAN-C5NR89CXH6O
Description:
The description for Event ID ( 6161 ) in Source ( Print ) cannot be found.
The local computer may not have the necessary registry information or
message DLL files to display messages from a remote computer. You may be
able to use the /AUXSOURCE= flag to retrieve this description; see Help and
Support for details. The following information is part of the event:
mhtml:mid://00000029/, Owner, Canon i450, NT EMF 1.008, 31484, 0, 1, 0,
\\VAN-C5NR89CXH6O, 2 (0x2), .
Sponsored Links
> cartridge.
> error . It`s
> latest updates
> SP2) IE 6 and
> Outlook express.
>   >>>>Event Type: Error
> Event Source: Print
> Event ID: 6161
> Date: 12/15/2004
> Time: 6:08:13 PM
> User: VAN-C5NR89CXH6OOwner
> Description:
> cannot be found.
> information or
> You may be
> see Help and
> event:
> 0, 1, 0,
I have a Canon of another model, but have had a problem now and then
about the same as yours. Disconnect the USB cord and reinstall with
the CD that came with the printer. After it is reinstalled put the
cable back and things should be OK. Good luck
http://www.WindowsForumz.com/ This article was posted by author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.WindowsForumz.com/Print [...] 40234.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.WindowsForumz.com/eform.php?p=729148
Reply to Anonymous
- 0 +
It worked. Your advice is OK. Thanks Phil
Reply to Phil
It sure feels good when the cure came to fruit. Thanks for letting me
and others know.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.WindowsForumz.com/eform.php?p=729342
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Printer problem 6161
There are 1159 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
