Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I've a strange printer driver behavior which I so far have not been able to
resolve. My printer is a Lexmark Z35 usb connected to a WinXpHome system. My
other network clients are WinMe systems. All Windows are Norwegian language
versions. I use a home network router. Prior to XPSP2 network printing was
performing fine, however once I applied the XPSP2 then client drivers could
not communicate with the remote printer. As I've got Northon Internet
Security on all systems, I've switched off the Microsoft Security Center
firewall. Local printing on XP remains fine. If I remove the XPSP2 all is
back to previous state with the client network printing working fine. Any
idea where to look to solve this will be very much apprechiated.
Contact Lexmark on this. I'll forward this to the Lexmark test team at
Microsoft. They were working on this but the solution they came up with
never worked.
This posting is provided "AS IS" with no warranties, and confers no rights.
"Anton" <Anton@discussions.microsoft.com> wrote in message
news:BBF9B2A5-5B1A-45B8-9B50-20371F0CEAFB@microsoft.com...
to
My
language
could
Appreciate your effort to help solve this both with Lexmark and Microsoft.
I'm however puzzled as the only change to my environment was XPSP2. Also I
noticed an earlier reference to a beta of the servicepack which did not
interfere with this kind of home network printing setup. May be Microsoft is
in a better position to solve it?
> never worked.
> Alan Morris
> Windows Printing Team
> Search the Microsoft Knowledge Base here:
> http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
> to
> My
> language
> could
Not sure who needs to fix it but Lexmark understands it's a DCOM issue.
It's an issue with the DCOM communication interface. I gave the Lexmark
instructions to another user and it did not help them. Let me know how this
works for you and I will inform the Lexmark driver developers.
From Lexmark:
Below is an excerpt from our development staff that was sent to the TAM when
we first noticed the problem:
"Our current printing solution uses a DCOM application
to provide client applications with print path, printer status and
printer configuration. Our current implementation also supports remote
(machine) peer-to-peer printing with printer status.
When we apply Service Pack 2 to a Windows XP machine, peer-to-peer
printing no longer functions correctly. We notice that our DCOM
application (which runs as a service) gets launched, but the remote
client gets an 'access denied' error (5) when it tries to use the
interface. We did some investigation with DCOMCNFG and noticed that we
were able to print when the machine-wide settings were modified as
follows:
DCOMCNFG- > 'Configure my Computer' button -> COM Security -> 'Access
Permissions' Edit Limits -> 'Remote Access' for Everyone=checked.
Prior to the change, the allow and deny settings for Remote Access were
blank, which we understood to mean that the application's settings were
to be used. This leads us to our question: From a DCOM point of view,
what is the exact meaning of the new 'Security Limits' part of DCOMCNFG
and what does it mean if a particular field is blank (that is, neither
Allow or Deny is checked)?
Some background information may be useful. Our component specifies
'Connect' and 'Identify' as it's communication property at runtime with
CoInitializeSecurity(). It specifies launch and access permission via
the Registry under HKCR\AppId\{application guid}."
This gives a basic understanding of why Lexmark uses DCOM and what we try to
do in the Peer to Peer configuration. We basicallly use the DCOM
application for our bidirectional communications and we try to perform the
communications via a Peer to Peer connected printer.
As far as when it broke, we first noticed the problem in RC1 of the service
pack. We started the escalation then, but noticed it was fixed in RC2. By
fixed, we basically mean the defaults for these settings were changed. When
the RTM came out, the default settings for the COM Security were set back to
the way they were in RC1.
We have worked on a method that will allow us to programatically change
these settings, but we would need to prompt the user to let them know we are
trying to make this change and would like to steer away from this if at all
possible. I was waiting to get this out to make sure it was possible for us
to make this change.
news:A136CB09-0789-494C-80B1-46440EA5FB34@microsoft.com...
is
> > never worked.
> > Alan Morris
rights.
able
> > to
system.
> > My
> > language
was
> > could
Center
is
Any
Difficult to follow up on my system as all labels etc are in norwegian and
anyway none of the branches available to follow after having started dcomcnfg
leads me to remote access parameter. In fact I did try this over a month ago
(as well as other suggestiones including cleanly removing Lexmark drivers).
If you can express the instructions in registry terms?
> From Lexmark:
> follows:
> End Lexmark
> Alan Morris
> is
> > > never worked.
> > > Alan Morris
> rights.
> able
> > > to
> system.
> > > My
> > > language
> was
> > > could
> Center
> is
> Any
news:500B931E-D500-45D1-A629-71A280F74872@microsoft.com...
dcomcnfg
ago
drivers).
Lexmark
this
> > From Lexmark:
when
> > follows:
try to
the
service
By
When
back to
are
all
for us
> > End Lexmark
> > Alan Morris
rights.
Microsoft.
Also I
not
Microsoft
> > is
at
with
> > > > never worked.
> > > > Alan Morris
> > rights.
been
> > able
> > > > to
> > system.
> > > > My
> > > > language
printing
> > was
drivers
> > > > could
Internet
> > Center
all
> > is
fine.
> > Any
I finally found the items indicated by Lexmark, however the setting was
already to allow remote for all. Tried all blank, but no change. Left the
value as I originally found it i.e. allow.
Anything else they or you would like me to try?
> no clue on this.
> Alan Morris
> dcomcnfg
> ago
> drivers).
> Lexmark
> this
> > > From Lexmark:
> when
> > > follows:
> try to
> the
> service
> By
> When
> back to
> are
> all
> for us
> > > End Lexmark
> > > Alan Morris
> rights.
> Microsoft.
> Also I
> not
> Microsoft
> > > is
> at
> with
> > > > > never worked.
> > > > > Alan Morris
> > > rights.
> been
> > > able
> > > > > to
> > > system.
> > > > > My
> > > > > language
> printing
> > > was
> drivers
> > > > > could
> Internet
> > > Center
> all
> > > is
> fine.
> > > Any
