G
Guest
Guest
I got a Delta 80mm 80.1 CFM 5200 RPM Fan that I'm using as a processor cooling device. Anyways, as you all probally already know, or are thinking, this fan is =-*LOUD*-=!! Anyways, I want to find some way to reduce the speed of it, and one of the ways I have found is by the use of a Rheostat. I have found guides to complete this and make it possible, the only problem is, my fan is 10.8 watts!! I can't use a 3 watt nor a 5 watt Rheostat for this, the thing would be dissipating toooo much heat and would melt. It's becoming hard to find a 25 ohm 15 watts Rheostat, so if any of you electricians out there have some advice for me to reduce my speed, please be my guest and share the info. I went to #Electronics on irc.dal.net, they laughed when I said the guide called for a 3-5 watt Rheostat, or 1/4 ratio, Cpu Wattage to Rheostat. They believe a 1.5 ratio is best, for example for a 10 watt fan, a 15 watt Rheostat. They also came up with 25 ohms for me. Anyways heres the specs of the fan incase you do not know them. Btw I would like some form of way so I can atleast change it from high to low, I don't want to just decrease the speed permanently, I want it like low at night, and high when I'm playing games.
Specs:
- 80mm x 38mm
- 12v
- .90 amp
- 10.8 watt
- 5700 RPM
- 80.16 CFM
- 52.5 dBA
- 3 pin connector (must used adapter to 4 pin)
Specs:
- 80mm x 38mm
- 12v
- .90 amp
- 10.8 watt
- 5700 RPM
- 80.16 CFM
- 52.5 dBA
