hey, my new system is:
Athlon XP 1900 with Dragon Orb 3 (7000RPM)
VisionTek Xtasy GeForce 4 Ti4400
256MB DDR266 ECC CL=2.0 ...kingston
Soltek SL-7DVRV4
Maxtor 40GB 7200RPM ATA133
I thought OC'ing would be simple, but now that im trying, i cant seem to get it up very high at all. It runs perfectly fine with FSB at 140. 145 is unstable and freezes in UT.
There are alot of settings like CPU/DRAM/AGP/etc. skew settings, DRAM burst length, Dram Que Depth, Dram Command Rate, AGP Master 1 WS write/read, and also all the voltage settings for ram, cpu, etc.
Which settings are important for OC'ing, and which should i change. I had hoped to at least get the FSB to 150, and even thats not that much right? Should i be able to get it to 160? The multiplier is 12, because its not unlocked.
Im running Windows 98, and there are a few other problems to. Ill be upgrading to XP soon, so hopefully that will help. For instance, i cant run the geforce 4 Ti demos, except for the creature, because of some DLL.sound somthin or other.
Basically i just need help knowing what settings to change, and what to change em too. This mobo also has a feature called RedStorm OC'ing, where it changes the FSB for you, but so far it hasnt worked.
PS. Does anyone know how to create a demo in UT to find out the frame rate???
THX
The first LAN I went to was at a PETA convention. They booted me after I shot a zombie in HL DM!
Soltek SL-7DVRV4
THX
