Problem: only the first page of the Fax arrives at the des..
GIGI
26
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi.
After a long time, I tried to send a Fax with Windows XP, and surprise:
The button for adding jpg-Files for example, dissapeared, so I can send just
1 File now.
The next problem is, that I can sent more then 1 page from that file (the
faxmonitor shows that), but only the first page arrives at the destination
Thanks,
Mihai
G
Guest
Guest
Post the precise steps you are using and the behavior you see.
Russ Valentine
[MVP-Outlook]
"Gigi" <telefon@justmail.de> wrote in message
news:41f27098$0$822$9b4e6d93@newsread2.arcor-online.net...
> Hi.
> just 1 File now.
> Thanks,
> Mihai
GIGI
26
I have a 3 page doc-File and I say "File-Print" and then I choose the Fax.
Everything seams to be OK, but before I sent the Fax, in the Preview only
the first page is shown.
During the sending process, all the 3 pages are shown in the
faxmonitor-window( sending page 1, sending page 2....)
At the destination, only the first page arrives, as shown in the preview.
"Russ Valentine [MVP-Outlook]" <russval@mvps.org> schrieb im Newsbeitrag
news:uftF7qJAFHA.608@TK2MSFTNGP15.phx.gbl...
> Russ Valentine
> [MVP-Outlook]
>> Hi.
>> just 1 File now.
>> destination
>> Thanks,
>> Mihai
G
Guest
Guest
What document type and from what application are you sending?
What is the file association for TIF files in your operating system?
What do you see in your Sent Items Folder?
Do you get any error messages or see anything in Event Viewer?
Russ Valentine
[MVP-Outlook]
news:41f3b344$0$17614$9b4e6d93@newsread4.arcor-online.net...
>> Russ Valentine
>> [MVP-Outlook]
>>> Hi.
>>> just 1 File now.
>>> (the faxmonitor shows that), but only the first page arrives at the
>>> destination
>>> Thanks,
>>> Mihai
GIGI
26
It is a Word-Document and I send it from MS-Word.
In the Word-document I have embeded JPG-files, because Windows XP with
Service Pack 2, no longer admites attachment-files in the Fax.
In the Sent Items Folder I see the sented fax, but only the first page is
in.
I don't get any error messages.
>>> Russ Valentine
>>> [MVP-Outlook]
>>>> Hi.
>>>> just 1 File now.
>>>> destination
>>>> Thanks,
>>>> Mihai
G
Guest
Guest
Aha. Now you tell me. No wonder.
Your statement that you are no longer being able to attach JPG files after
SP2 is confusing. SP2 changed nothing. It has never been possible to add
attachments in Windows XP Fax's Send Fax Wizard.
Windows XP Fax is not able to render files. It relies on the print routine
of the originating application to do that. You are attempting to render a
JPG file from an application that has no such ability in its print routine.
Can't be done. JPG files must be sent separately using an application that
can render them.
Russ Valentine
[MVP-Outlook]
news:41f7dc00$0$804$9b4e6d93@newsread2.arcor-online.net...
> in.
>>>Fax.
>>> only the first page is shown.
>>> preview.
>>>> Russ Valentine
>>>> [MVP-Outlook]
>>>>> Hi.
>>>>> surprise:
>>>>> send just 1 File now.
>>>>> destination
>>>>> Thanks,
>>>>> Mihai
