G
Guest
Guest
Hi
I have some troubles oc'ing my R8500 since changing mobo. I use the rage3d tweaker and it has worked fine, tweaking the clocks with no trouble under XP.
Then I changed mobo to DDR, and now the tool says core/memory clock na, as in not available.
So I can't do anything. My mobo is updated with the latest driver and bios. Sounds like an AGP issue but I have no clue.
The card works fine with this new board, exceeding my previous 3DMark record by more than 1000 points (so what do I need to oc it for then, right?..well, it's there so...), so it works fine with the board, just not with the tweaking.
Anybody has any idea??
