Yes and Yes. <A HREF="http://www.Overclockers.com" target="_new">http://www.Overclockers.com</A> has some articles and how-to's on watercooling. Also, Koolance makes cases that already come with a water cooling system. <A HREF="http://www.plycon.com" target="_new">http://www.plycon.com</A> sells the koolance mid and full tower cases and accesories for the system. There are also kits out there if your are confident and competent enough to put it together. Tom's Hardware has a comparison of water cooling kits that you should check out. Innovatek and some other companies make pretty good kits. Also, I would reccomend you do a ton of research on water cooling to make sure you know what to do. Also, it would be a pretty good idea to test out the water cooling system on an old computer before putting it on your new comp so you know what to do and if you mess up, then you didn't destroy a perfectly good system. Good Luck!
P.S. I have some other sites about water cooling and I'll post them later.
Jesus may save, but <i>I</i> invest.
