Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Distinctive Ring for faxing
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I see many questions about the lack of the support for distinctive ring in XP
but all replies seem to direct users to a hardware solution. I don't think a
hardware solution will work for me and was hoping to find a software
solution. The reason I don't think hardware will do it for me is that I use
Call Notes (voice mail) on the main number and fax on the distinctive ring
number on the same line. I think these hardware devices will cause my VM not
to pick up the call??? Any suggestions???
Sponsored Links
Yeah I have similar set up with voicemail what you do is find out how many
rings until your voicemail picks up and set up your fax to answer one ring
later :) hope that helps, my voicemail answers on the seventh ring. so fax
answers on 8th
"Lincoln" <Lincoln@discussions.microsoft.com> wrote in message
news:A53B71C2-7346-4AF0-A151-75F24DC5024D@microsoft.com...
>XP
> a
> use
> not
Reply to glow
- 0 +
http://www.tucows.com/preview/247082.html
http://www.spyfind.com/bitware.html
or solve the problem and use one program for both, I would recommend
Cheyenne I was using it before I upgraded to XP.
>XP
> a
> use
> not
Reply to glow
- 0 +
Oh also supervoice is very good
http://www.hitec.com.au/supervoice [...] 4_old.html
http://www.supervoice.com/
used to have old version of it, must admit its fantastic, absolutely five
star but your paying for it.
>XP
> a
> use
> not
Reply to glow
There are 1282 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
