WHERE IS THIS GUIDE TO OVERCLOCKING AMD XP??
Just Looking for the GUIDE for OVERCLOCKING AMD XP
Can't Find it anywhere
IF IT AIN'T BROKE...........DAM IT, MAKE IT FASTER!!!
7 answers Last reply
More about where guide overclocking
  1. Are you looking for <b>how to overclock</b> athlon Xp or <b>how to unlock</b> it?
  2. I guess both, the same trick as before right?
    connect the L1 and L2 with a pencil??
  3. <A HREF="http://www.overclockers.com/tips693/" target="_new">here,</A> <A HREF="http://www.tomshardware.com/column/01q4/011124/index.html" target="_new">here,</A> and <A HREF="http://www4.tomshardware.com/howto/01q4/011112/athlonxp2000oc-02.html" target="_new">here.</A> These are just a few.... <A HREF="http://hwfaq.overclockersonline.com/dbase.php?catid=10" target="_new">here's</A> the most extensive listing of overclocking i've seen. Good Luck
    Jesus may save, but <i>I</i> invest.
  4. thanks, thanks, thanks and thanks dude
  5. when you get to toms main page look on the left all the way down under toms guides click cpu and scroll down
  6. <b><A HREF="http://www.ocinside.de/html/workshop/socketa/xp_painting.html" target="_new"><font color=red>Athlon XP Painting Guide</A></b></font color=red>
    :smile: Good or Bad have no meaning at all, depends on what your point of view is.
  7. thats a good link man!
    i used it a while ago...(same site, but for the athlon/duron).
    great guide! :smile:
    -DAvid
    -Live, Learn, then build your own computer!-
CPUs Overclocking AMD Windows XP
