Hello,
so I had everything working fine - Monitor + TV connected via s-video as dual screen. However I recently cleaned my PC, disconnected everything and after putting it back together, it doesn't work..
Before both the monitor and the TV used to show the POST message, but now, only the monitor shows this. Its like, the PC doesn't pick up the s-video anymore. I can go into 'screen resolution' and try to extend the display onto the tv but I get this annoying error message that says "unable to save display settings".
If I select to use the TV as a single display, this works fine so its not a cable problem or source problem. I think it could be something to do with the tv driver / device not being picked up but I don't see an obvious way to fix this in device manager.
Any suggestions / ideas?
Thanks!
Thanks!
