When I take the side of my case off the temp literally drops 4 degrees... with the front off my temp drops another degree. I've tried drilling the front out and I have no more room for vent holes.
I just bought 3 panasonic panaflo fans now that push out 40CFM - the first I am installing in the front to suck air in, the second in the back to push air out.
I noticed Milenko said to push more air in than you do out to raise the pressure, but I have no other places to mount a fan in the front.
My original plan was to mount a blowhole on top, but should I instead make this a "suckhole" or should I drill a hole in the side of the case for a fan... or would this cause too much turbulence?
I guess I'm looking for the best remaing option - any help would be appreciated.
