Stupid question about fan speed
I know this may sound dumb, but I just want to make sure. Right now I have a CPU fan running at 5400rpm and it's probably gonna be running that fast forever since I'm OC. But I connected it to those speed things where you adjust the voltage to turn down the rpms... So anyways can I just take it off and connect it straight the the motherbaord and will it just operate at 5400rpm? I would guess yes, but I'm not really sure. If the voltage/speed selector doesn't need to be there, I wanna take it out cuz I don't care about noise. Thanks in advance!
1 answer Last reply
More about stupid question speed
  1. You can do that. In fact, a 5400RPM fan should work fine on your board (some 7000RPM fans were overloading the circuit).
    What's the frequency, Kenneth?
Heatsinks CPUs Fan Speed Overclocking
