Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Print Spooler not Running
Forum Windows XP : General Discussion Print Spooler not Running
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have a chicken & egg problem. My print spooler is not started. I tried to
start it and it says there are no printers. I try to add a printer and it
says my spooler has not started. I'm using XP Home Edition with SP2 and a
Canon i560 printer.
Reply to atom
What is the exact text of the message that appears when you type:
net start spooler
(as per http://www.coribright.com/windows/Article%20Nine.htm)
Cari (MS-MVP)
Printing & Imaging
In Loving Memory of our dear friend Alex Nichol MVP
"atom" <a_tom50@hotmail.com> wrote in message
news:383FA4C0-F1BC-4BB6-9282-A3451CDA9DB1@microsoft.com...
> Canon i560 printer.
Reply to Anonymous
I recently have had a similar problem and this command did not fix it. I get
another error message which says "The dependency service or group failed to
start. I believe it was with ERROR 1068.
> net start spooler
> Cari (MS-MVP)
> Printing & Imaging
> > Canon i560 printer.
Reply to Anonymous
Try
net start RPC
net start spooler
each line followed by enter and executed from the cmd interpreter.
Tom
MSMVP
Windows Shell/User
"psypher" <psypher@discussions.microsoft.com> wrote in message
news:D0A6C130-6D65-4B76-89E5-1DCB17F85FC3@microsoft.com...
:I recently have had a similar problem and this command did not fix it.
I get
: another error message which says "The dependency service or group
failed to
: start. I believe it was with ERROR 1068.
: "Cari (MS-MVP)" wrote:
: > What is the exact text of the message that appears when you type:
: > net start spooler
: > (as per http://www.coribright.com/windows/Article%20Nine.htm)
: > Cari (MS-MVP)
: > Printing & Imaging
: > In Loving Memory of our dear friend Alex Nichol MVP
: > "atom" <a_tom50@hotmail.com> wrote in message
: > news:383FA4C0-F1BC-4BB6-9282-A3451CDA9DB1@microsoft.com...
: > >I have a chicken & egg problem. My print spooler is not started. I
tried to
: > > start it and it says there are no printers. I try to add a printer
and it
: > > says my spooler has not started. I'm using XP Home Edition with
SP2 and a
: > > Canon i560 printer.
Reply to Anonymous
Thanks Tom. I tried both and still get the window asking if I want to start
the print spooler, which I indicate 'yes' and nothing happens. I also get
this message and recommendation from the XP Library with this notation for
this error:
Error Message: The dependency service or group failed to start.
Explanation: An application has attempted to start a service. However, the
service did not start because one or more services that it depends on failed
to start.
User Action: Use Event Viewer to look in the event log for details about
the dependent service or group that failed to start.
Then what, after finding the 'dependent service'? I need to get more info
on this process and will be searching the XP site. I am attempting to
install a Lexmark printer, but I don't think it matters what printer with
this particular problem. Windows XP, SP2. I also wonder if any recent
'updates' would impact this process.
"Thomas Ferguson" wrote:
> Try
> net start RPC
> net start spooler
> Tom
> MSMVP
> Windows Shell/User
> I get
> failed to
> : > Cari (MS-MVP)
> tried to
> and it
> SP2 and a
Reply to Anonymous
- 0 +
Thank you all for your effort. I fixed the problem by going into Control
Panel>Administrative Tools>Services>Print Spooler>Properties. On the "Log On"
tab - my Hardware Profile was disable and I enable it. That fixed my problem
and the spooler started working and all my printers showed up.
> this error:
> to start.
> > Try
> > net start RPC
> > net start spooler
> > Tom
> > MSMVP
> > Windows Shell/User
> > I get
> > failed to
> > : > Cari (MS-MVP)
> > tried to
> > and it
> > SP2 and a
Reply to atom
See steps 15 through 17 at Bruce Sanderson's website at:
http://members.shaw.ca/bsanders/Cl [...] rivers.htm
Cari (MS-MVP) Windows Client - Printing & Imaging
www.coribright.com
news:E8A29EFE-53A6-46A8-A18D-0660D80E4570@microsoft.com...
> start
> this error:
> the
> failed
> to start.
>> Try
>> net start RPC
>> net start spooler
>> Tom
>> MSMVP
>> Windows Shell/User
>> I get
>> failed to
>> : > Cari (MS-MVP)
>> tried to
>> and it
>> SP2 and a
Reply to Anonymous
Thanks! That was the solution! Everything is working fine.
> www.coribright.com
> > start
> > this error:
> > the
> > failed
> > to start.
> >> Try
> >> net start RPC
> >> net start spooler
> >> Tom
> >> MSMVP
> >> Windows Shell/User
> >> I get
> >> failed to
> >> : > Cari (MS-MVP)
> >> tried to
> >> and it
> >> SP2 and a
Reply to Anonymous
There are 1958 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Microsoft Updates - In Triplicate !
By Hawkeye22, 1 day ago:
They won't show up in add/remove programs because they were superceded by a different...
Best offers
Top experts
