G
Guest
Guest
Hi All,
I have read the new <A HREF="http://www17.tomshardware.com/howto/02q3/020701/index.html" target="_new">Silent and Ice Cold</A> article.
(BTW the multi languages water cooling mounting video was fine. )
I am interesting to switch my HSF to a water cooling kit though it costs round double the price of an HSF with almost the same performances. The cpu cooler, the pump as the heat exchanger are very imposing & impressive.
#flat1: I think that the Innovatek Hard Disk Water Cooler is not very efficient because it cools only both sides but not the upper & the lower parts of the disk.
#flat2: You need a huge size case to succeed placing both the large heat exchanger as well as the PSU. How could we do otherwise?
It's a good silent cooling method & efficient as such noisy high cooling HSFs (& even more) but there are three annoying things.
The first one is that a leak of water is always possible to occur & then a great part of the electronics components could be irremediably destroyed. In that case you can have 2000 dollars of equipment fried in one instant.
Moreover how much time the plastic tubes remain secure? (physically the plastic becomes crackly after a certain period, it can split itself & creates leaks) What is the secure MTBF for a water cooling system?
The second point is the water tube assembly obstructs the case & hinders manipulations under it. This could be disturbing for an overclocker's computer. Is there a remedy to improve that?
The third point is you can buy only a simpler water cooling kit which cools uniquely the cpu then a complet HSFs & fans equipment which cools cpu, gpu, chipset, memory & hard disk likewise at the same cost around $200.
Then i am wondering which cooling equipment should i buy?
Welcome on this topic!
<i> I like Interactive THG!</i>
