300W Power supply?
ian1386
9
One other question for you fellows today:
I plan to but an In-Win case for a 1.8A clocked to 2.4, and I'm just wondering if the included 300W power supply will give it enough juice to ramp her up? It's going to be a Giga-byte 8IEXP mobo with built on raid, firewire, etc., and as far as other components, It'll just be a maxtor 60gb drive, a burner, a ti4200 64meg card, and either 256 or 512 of PC2100 ram.
What do you guys think?
<P ID="edit"><FONT SIZE=-1><EM>Edited by ian1386 on 07/21/02 08:11 PM.</EM></FONT></P>
Cruiser
82
It depends on the quality of your PSU. If it´s good quality it might run stable enough, but I would recommend a 400W+ PSU for your system, since you´re overclocking. Antec, Enermax or Codegen are all good quality.
Cruiser is right. With a system like that one, it would be wise to go for the best (not necessarily the highest output) PSU you can afford.
It's a part you can't do without, so make sure it's good.
<b><font color=blue>~ What do you mean "It isn't working!"...Now where's my sonic screwdriver? ~ </font color=blue></b>
kdo2milger
176
<font color=red><b>HIGHLY RECOMMENDED</b><font color=red>
ENERMAX EG465P-VE(FCA). 431W Power supply for AMD K7 & Pentium4. Meet AMD K7 and Intel ATX +12V 1.1 and ATX 2.03 version (Pentium 4 fully support). Ultra cooling design: one 9 cm fan intake heat and one 8 cm fan exhaust heat. FCA function (Fan On/ Off Controlled by M/B & Adjustable), "sleeping mode" . 9cm Thermal Control Fan.
<font color=black>It's the eleventh PSU down the page...</font color=black>
link:
<A HREF="http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=58&manufactory=1400&DEPA=1" target="_new">http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=58&manufactory=1400&DEPA=1</A>
<font color=red><b>Wealllovedisassemblingthingstoseehowitworks,butwhowantstoputitbacktogetheragain?
pr497
1,343
i know a website that sell's enermax 350w PSU for about $53...if you're interested that is...
:eek: <b>L <font color=red>A</font color=red> e <font color=red>T</font color=red> a <font color=red>I</font color=red> K</b> :eek:
TWC
289
I have the same setup and could not make it run until I upgraded my powersupply,i bought a antec 350w.
"I'd rather laugh with the sinners than cry with the saints."
