Tom's Hardware > Forum > Games General > Games General Discussions > Help, Black screen but sound when running games
Forum Games General : Games General Discussions - Help, Black screen but sound when running games
I'm waiting for my Dell to arrive and I had the urge to play something so I decided to install Myth II on my old PC, pIII 450. I go through the install setup but when it comes to running the game all I get is a black screen and the sound of the game. I tried Heroes II and I got the same problem. The games have worked before on this PC and I haven't done any hardware changes whatsover so could someone plz help me find a solution.
Sponsored Links
I got this problem once, turned out it was a bad INF driver for the monitor. Check that.
Reply to Ganache
I messed around with some of the monitor configurations but I'm not very computer literate so could you tell me how I can check the INF driver? Thanx again
Reply to Ultrageek
I just tried again and I realised my monitor makes sound (like when I shut the computer off) and its light starts going on and off successively. I'm not sure if this may mean anything. When I hit ESC since I cant see anything it returns normally to the windows screen. Help
Reply to Ultrageek
Sounds like you're attempting to run in bad resolutions, and the monitor's just powering off to prevent damage. Try deleting or renaming the game's config file, and lowering your desktop resolution to 1024*768*60Hz, then run the game again.
Reply to goblinking
Also, check if it's all games or just some. I haven't seen a system that had general problems with exclusive (fullscreen) modes, but that's not to say it isn't possible.
Reply to goblinking
It worked, I messed with the monitor resolution and it runs now. Thanx!
Reply to Ultrageek
Hello I am haivng the same issue, with every new game I install, it is either
Black screen
Flickering towards my background
or I just see the windows borders when I try playing it in windows.
- Changing my Resolution back doesn't help
- I updated everything to its current
- I thought it was Java, and somewhat still think that.
- I restored all my graphics settings on my Nvidia 9800 GX2
I am at a breaking point of my games running in black screen, and ready to take a bat to my graphics card.
Reply to Acidblood7
did you check the plug for your monitor?
Reply to grlnxtdoor
There are 989 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
