Archived from groups: microsoft.public.windowsxp.print_fax (
More info?)
Hi again Erikka,
Have just solved the problem, When in paint I then save to my documents and
then print.
Thanks again.
"Franktee" wrote:
> Hi Erikka T,
> Have followed your instructions but am still getting the same result. (2
> sheets I/O 1).
> Thanks for your reply.
> Franktee
> "Erikka T" wrote:
> > Hi Franktee,
> > Try this-- Open Paint, and go to Image | Attributes. Change both the Width
> > and Height to = 1. Make sure that Units = Pixels. OK to save changes, and
> > then go and do your printscreen again.
> > After making these changes, hopefully the next time you paste, you will be
> > prompted with a message that the size of the object is bigger than the
> > available space, and Paint will automatically resize it for you so that it
> > all fits in one image. Either that or Paint will just resize it for you with
> > no message. Hope this helps.
> > "Franktee" wrote:
> > > Hi Cari
> > > Thanks for your response.
> > > Yes, tried landscape mode but am still getting the printout on two sheets.
> > > The left hand side of the picture on one sheet and the right hand side of the
> > > picture on a second sheet. I am looking to get the entire reproduction on
> > > only one sheet, (if that's possible).
> > > Franktee
> > > "Cari (MS-MVP)" wrote:
> > > > Did you try printing in landscape mode?
> > > > Cari
> > > > (MS-MVP Printing & Imaging)
> > > > "Franktee" <Franktee@discussions.microsoft.com> wrote in message
> > > > news:B70061DA-A0BC-457F-A4B1-7E20D14C70DC@microsoft.com...
> > > > > Sorry for being unclear..
> > > > > Have saved an object by hitting the "print screen" key on the keyboard.
> > > > > That
> > > > > object is now in the "paint" feature of windows xp home ed. When trying to
> > > > > print the object by hitting edit and then paste the picture breaks up
> > > > > into
> > > > > two half sections which means I now have to print two pages (one for each
> > > > > side of the picture) to get the complete picture. I need to have the full
> > > > > photo on only one sheet. Hope I was able to explain it correctly this time
> > > > > since I am an older newbie. Thanks for your help and patience
> > > > > "Miss Perspicacia Tick" wrote:
> > > > >> Franktee wrote:
> > > > >> > Hi All
> > > > >> > Am trying to print in screen mode while in paint, but am getting two
> > > > >> > half sided objects when printing . How can I get just one complete
> > > > >> > picture on just a one sheet printout.
> > > > >> > Thank you.
> > > > >> Not sure I follow. What does "print in screen mode" mean? What does "two
> > > > >> half-sided objects" mean?
> > > > >> In fact, what does your entire post mean?
> > > > >> In memory of MS MVP Alex Nichol: http://www.dts-l.org/
