Purging print job problems.
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Every once in awhile you need to cancel mult-paged jobs. It doesn't work
every time. I do not know what the condition that causes this but the only
way to get things to purge is to turn off the darn printer and pc, wiat a few
minutes and turn it all back on. Is there anyway to manually dlete things in
the queue? This is a great weaste of time.
I've seen it happen on different computers and printers in different
locations. All on windows. Currently occurs on Winxp. Why can't we find
stuff in the buffer and dlete it?
Tom From New England
2 answers Last reply
More about purging print problems
  1. Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
    You must cancel print jobs if You make mistake and only printer off x times
    (x=number of pages) for empting spooler. Spooler need a long time fort
    empting itself
    advo@siol.net
    "Tom from CT" <TomfromCT@discussions.microsoft.com> je napisal v sporoèilo
    news:3F802820-49CB-4CCC-AF10-CEF44CC8DE19@microsoft.com ...
    > only
    > few
    > in
  2. Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
    Some printers have a control panel that will allow you to pause the job at
    the printer, and clear the internal printer buffer. At this point, you may
    also be able to also flush the printer spool buffer. I'd suspect that the
    problem really occurs due to the way the particular printer drive was
    written, and what features were and were not implemented.
    One of my printers requires that you first pause the spooler/driver, then
    flush or reset the printer. Next, the spool file is deleted. Another of my
    printers will print the current block of data, then respond to the delete
    job command, and then the spooled file is deleted as you would expect. Both
    are printing jobs from the same PC, however one is connected to a USB port
    on the PC, and the other via a wireless print server.
    "Tom from CT" <TomfromCT@discussions.microsoft.com> wrote in message
    news:3F802820-49CB-4CCC-AF10-CEF44CC8DE19@microsoft.com...
    > only
    > few
    > in
Printers Windows XP
