Been doing alot of playing lately with new board, cpu, and water cooling kit. Before I begin here are my specs:
EPOX 4G4A+
P4 1.6a @ 2.48 620 FSB 4:5 mem ratio (ROCK SOLID, endless 3dmark and prime95 loops)
GEIL PC3500 433 mhz memory
Innovatek water cooling
Idle temp: 39 C
Load Temp: 50 C MAX
Enermax 350 watt Power Supply
My system seems to be stable at times when I go to 2560 mhz and sometimes unstable. This meaning I Can run prime95 at times for 10 hours and sometimes only 5 mins!. Both under controlled conditions with nothing else running in the background. My main question is if my Power supply is too weak. If my cdrom spins up, I can hear my cpu fans slow down during the process. My 5 volt line is really dropping low.
Under Load
+5.00 : 4.89-4.92
Idle
+5.00 : 5.03-5.05
Would my 5 volt line dropping to 4.89 help cause the instability I'm getting at higher FSB? If so, what would be a good Power supply to remedy this? Thanks all
Cash
EPOX 4G4A+
Idle temp: 39 C
Load Temp: 50 C MAX
Under Load
+5.00 : 4.89-4.92
Idle
+5.00 : 5.03-5.05
Cash
