Archived from groups: microsoft.public.windowsxp.print_fax (
More info?)
Nice job!! Next time though, could you be a kittle more condescending?
"Miss Perspicacia Tick" <test@test.com> wrote in message
news:N58me.2797$C72.2376@fe06.highwinds-media.phx...
> Lhyde85 wrote:
>> I had to download Adobe Acrobat so that I could download an
>> application, problem is I cant print out the application. Everytime I
>> try to print it the pages come out blank!! If you can be of any help
>> to me PLEASE LET ME KNOW!!!!
> Your post makes absolutely no sense whatsoever.
> 1) Adobe Acrobat is commercial software and, as such, not available for
> download (at least not legally). I would venture to suggest you mean Adobe
> (Acrobat) Reader.
> 2) You don't print out "applications". Adobe Acrobat is an application
> used for the creation, reading and printing of PDF (Portable Document
> Format) files. Adobe (Acrobat) Reader is an application used for the
> reading and printing of PDF files.
> Are we to assume that you have downloaded Adobe (Acrobat) Reader and you
> are attempting to print a PDF file?
> If so, could you tell us *exactly* (including the verbatim text of any
> errors) what happens when you try?
> In memory of MS MVP Alex Nichol: http://www.dts-l.org/
