Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Help me Improve my case cooling
Forum Overclocking : Cooler and Heatsinks - Help me Improve my case cooling
<A HREF="http://members.bellatlantic.net/~vze29qyj/Untitled-1.jpg" target="_new">My Case diagram</A>
Suggestions on how to improve my case cooling?
Sponsored Links
what exactly do you want us to modify? i mean, what needs to be fixed or modified in your case cooling layout that you want to improve? Are you trying to make the ram or the cpu or the vid card cooler? If it's for the cpu, why not make a blowhole for your processor? There are a bunch of plans out on the net. Also, try taping up or putting caulk or something like that on all of the small gaps and holes in your case so that you have a more closed environment. Also, be sure to use that air in a can (not like the stuff from Spaceballs) to blow out all the dust because when that stuff starts to accumulate, your temps start going up.
Save the trees.. wipe your ass with an owl.
Reply to Mnx4
Well I overclock both my cpu(xp1700) and gpu(radeon 8500). Maybe you can tell me how I can improve my airflow.
Reply to LancerEvolution7
Intake, intake, intake...you say there is no hole in the front for an intake fan, so cut one! Use a dremel for the open air do the measurements (twice), use a drill for the screws. Aside from that, you could also add a side fan that blow directly onto your gpu. This would require cutting into the side panel of your case and adding a fan there.
If you don't feel the desire to cut, then I would suggest a new case before you start overclocking. Check out <A HREF="http://www.newegg.com" target="_new">newegg</A> and look at the cheiftech cases there.
Disclaimer: Please use all the appropriate safety equipment when attempting this, and make sure you take you computer OUT of the case before cutting.
-zigzag
Reply to zigzag
There are 1158 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
