Archived from groups: microsoft.public.windowsxp.print_fax (
More info?)
Thanks for trying, Byte. I resolved the problem. I bought a brand new
Panasonic Fax machine for $40 (after rebate). As you said, XP Fax has many
problems. I've spent way more than $40 of my time trying to use that. In
fact, my past experience in the PC industry was difficult with any PC-Fax
software. But I'm not technical enough to understand why this application is
so difficult, but it seems to be.
"Byte" wrote:
> I am presently stumped, for I have no additional info to give you.
> I do not use XP Fax due to the many problems this app has. Suggest
> you create a new post with the subject of help with XP faxing.
> Some days you're the windshield,
> some days you're the bug.
> "korndorb" wrote:
> > Turning off Norton Internet Security did not fix the problem. I still just
> > receive page 1 of multi-page faxes. Please help me.
> > "korndorb" wrote:
> > > I'm still the bug and not the windshield. I went to that "internet options",
> > > but I saw nothing that might resolve the problem. Since I suspect it might be
> > > something to do with Norton Internet security, my next effort is going to be
> > > to turn that off and see if the problem is resolved. Unless someone has a
> > > better suggestion...
> > > "Byte" wrote:
> > > > Your firewall, Security or Anti-virus may be blocking it. Do some
> > > > troubleshooting in: Start>Control Panel>Security Center>Internet Options
> > > > "korndorb" wrote:
> > > > > I have successfully been using XP Fax for a couple years. In last 2 weeks,
> > > > > though, when I receive a fax and get "successfully received a fax", the fax
> > > > > is not there. I did a search for any .tif file and found one - but it was
> > > > > only the cover page. I deinstalled and reinstalled XP Fax, and that did not
> > > > > help. While reinstalling I got lot of Norton internet security warnings
> > > > > telling me they'd protected me from an intruder.
> > > > > Any suggestions on how to fix this problem?
