Hi everyone. I just finished building a new machine with the intent of overclocking it. Today I was attempting to do just that, but have been pretty disappointed with the limited overclocking performance I have had.
I purchased an Asus P4T-533C mobo and also had a chance to use a Gigabyte 8IHXP mobo. These are both 533mhz capable-mobos. I purchased 1GB of 1066 Rambus RDRAM.
For a processor I went with the P4 2.4ghz/400FSB based on what I've read here on Tom's Hardware that this processor would have more FSB overclockability potential than it's 533 cousin. (that is...because you can start at 100mhz bus frequency (factory) vs. starting at 133 (factory), leaving more overclocking leeway on the way up to 150FSB)
Well, I configured the system with a Swiftech MCX-4000 HSF (amazing air cooler...very low CPU temps)...and would consider watercooling if necessary...but I can't even get that far.
On either of these two very highly rated and very overclockable mobos, I can't get the bus past 112 and get past POST. At one point I got through POST at 115 but then windows xp hung on boot. I have tried VCORE voltages starting at 1.5 stock all the way up to 1.85. The CPU never has a chance to get past about 35C on the digital doc (or motherboard monitor) as I can't even get much past boot in any kind of overclock mode.
With the bus at 112 it yields a CPU speed of 2688mhz, a terribly poor OC performance from this 2.4ghz chip. Especially considering the mobo is 533 capable and I'm using the expensive 1066 RDRAM.
Anything I'm doing wrong? or should I consider trying a different processor? Was it a mistake to use the p4/400 for this machine?
TIA
carey
TIA
carey
