I am interested in converting all my cooling fans to water cooling and cooling my hard drives with water so that I can encase them and reduce noise (I want an essentially noiseless computer).
I just read this fairly aged article http://www.tomshardware.com/cpu/01q2/010528/index.html .
Essentially I am asking if I can use their idea of using a water block on my P4 2.26 (socket 478). There is a temperature hole that obviously should not be covered, but I don't know if it's a good idea or just foolish.
If that is safe, then I want to do the same for my GeForce4 chip and adhere water blocks to my hard drives with thermal paste that will transfer heat to the block.
