Water blocks for Slot 1 CPUs
  • Heatsinks
  • Cooling
  • CPUs
  • Overclocking
October 22, 2002 7:43:14 PM
Does anybody, other than Danger Den still make/sell water blocks for Slot 1/SECC II CPUs? I have looked around and have been comming up empty.
I am new to this type of cooling so I don't know if any of the newer blocks can also be used for the older CPUs. I do know that I would need side mounted connections since I have a dual CPU box and there is not enough room for any of the top mounted style water blocks.
Any information would be a help,
TIA
More about : water blocks slot cpus
October 24, 2002 3:01:03 AM
Actually I am in the process of building a new dual AMD system. It will also be water cooled if I can figure out how to do it, but while I am getting all of the parts for the new system I was going to switch my old system to water. [Get my feet wet so to speak ;) ]
I saw in another post someone mention that Danger Den had slot 1 coolers but after emailing them I found out that they are only for slockets. That is why I am posting up here for any info that I can find.
October 24, 2002 7:14:59 AM
you could just take a socket cooler and thermal epoxy and zip tie it on to the core of your slot proc... thats what I would do that way you could just take that cooler off and put it on your dual system. save some cash and it will be easy to do, my cooling soultion is almost completely jury rigged and I just increased the number of fans in my rig to 16 from 15, I need a suck hole on the bottom of the case still... 13 of those fans are 80mm two are 40mm and one is 120mm. I love this chieftech case WOAH you gave me a great Idea! water case cooling...copper pipes running all along the inside of the case it just might work! it would certainly cut down on the noise
Life (n). A sexually transmitted disease which afflicts some people more severly than others.
save family guy via this link!
<A HREF="http://www.petitiononline.com/savefg2" target="_new">http://www.petitiononline.com/savefg2&lt;/A>
