I recieved my new volcano 9 CPU cooler a few days ago. When I recieved it I noticed deep rings from the outside to the inside that look like machining/manufacturing marks. At the time I was worried because I had read many reviews about this and they all said that it was supposed to be smooth without any imperfections. I decided to try it anyway. Now I am using at the moment a 1.4gig T-Bird. I have used Arctic Silver 3 for both heatsinks I used. Before this HSF I had a cheapy globalwin aluminium HSF. Just a real cheap and nasty one only rated to 1.3gighz to make it harder for it. Now at an ambient temp of around 27-28 degrees C the globalwin kept the CPU at around 51 degrees C under 100% load with divx 502 encoding. Now with the volcano 9 it is only able to keep the CPU at 54 degrees C under the exact same conditions with the volcano fan going at 4800rev and above the rated speed up to a max of 5661rev. Now I want suggestions on what I should do. I have sent an email to thermaltake but no response as of yet. I mainly want to know if this is a warranty matter to be returned to where I bought it or if I should just smooth off the copper insert myself with fine sandpaper.
Thanks for any suggestions.
AREA_51
AREA_51
