robthatguyx
1,155
will the ending you got for 2033 start the story for the next game? my original choice was to kill the enemy but i watched a video of the other option and was wondering if it would come into play in the next game. also does anyone have minimum requirements list?
The main ending where you launch the missiles is where Last Light will pick up, not the ending where you abort them. As for minimum I'm not sure exactly, probably fairly similar to 2033. Your 7770 should be fine.
iyzik
901
iyzik
901
No problem, and thank you :)
Found this I thought I'd post it real quick as it looked official enough to me.
http://digitalbattle.com/metro-last-light-system-requirements/
