OK, I've got some options for my new computer.
1: Buy a FullTower case: Chieftec Dragon Series: DA-01WD
and fans.
http://www.chieftec.com/products/dragon/da01wd.htm
I can have 5 fans in this case, 2 on the top, 2 on the bottom and 1 at the side..
One guy I talked to also suggested 1 sidefan, 1-2 on the bottom and then carve a hole in the roof for a 120mm fan..
OR
2:
http://www.thermaltake.com/products/cases/6000a.htm
Buy a Thermaltake A6000 Xaser II Aluminium..
Which includes 5 fans..
OR
the cheapest alternative
http://www.thermaltake.com/products/cases/5000.htm
Thermaltake Highest Xaser II 5000 Plus
What's the difference between steel and aliminium? other then weight?
The number 1 option will be about 60 dollars cheaper..
What should I do? Both considering price and not..
Sorry for bad english,
Thanks
<P ID="edit"><FONT SIZE=-1><EM>Edited by GuitarKalle on 11/10/02 08:17 AM.</EM></FONT></P>
and fans.
OR
2:
OR
Thanks
