Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Ok, i downloaded the CJ2012SE driver from the Lexmark website. I unzip
it to a folder. I look at the readme file and says Lexmark System
Driver
Date: August 7, 2001
Please close all applications before installing the driver.
This driver can only be installed through the Windows Add Printer
Wizard.
Click UNZIP on the next screen to extract the driver files.
Choose OK to continue with the Self-Extraction Program...
The problem is that I can't enter the Windows Add Printer Wizard. The
add printer button still doesn't work, so in order to install this
driver it seems like i have to get that button working.
Cari \(MS-MVP\) Wrote:
> Go to the Lexmark website (www.lexmark.com) and download the drivers
> from
> there for the Z12.
> Cari (MS-MVP)
> Printing & Imaging
> "Queb" Queb.1tzxq2@pcbanter.net wrote in message
> news:Queb.1tzxq2@pcbanter.net...-
> Well, i did as you said. I logged in as an administrator and went to
> command prompt and typed in net start spooler but it said that the
> requested service has already been started. So i go back into
> printers
> and faxes not knowing if it worked. I click on add a printer and
> still
> nothing happens. Any new suggestions?
> Cari \(MS-MVP\) Wrote:-
> Your print spooler appears to have stopped.
> http://www.coribright.com/windows/Article%20Nine.htm >
> And also remember you must be logged on as an Administrator.
> Cari (MS-MVP)
> Printing & Imaging
> "Queb" Queb.1txme7@pcbanter.net wrote in message
> news:Queb.1txme7@pcbanter.net...-
> Hello, i'm trying to install my Lexmark Z12 printer.
> So i install the software that goes with the printer. Thats no
> problem. Now obviously i can't start printing pages from the internet
> or Word without the OS identifying the printer. I go to control panel
> then click on Printers and Faxes. I click on the Add a printer button
> but nothing happens. I keep clicking and its like its not even there
> but it does highlight when i move my cursor over it.I click on the
> button below it which is set up faxing and that works fine. I click
> the
> troubleshoot buttons and thats fine. So i'm kinda confused why its
> just
> that button not working.
> I've looked through the help and support center and nothing really
> shows up with the problem i am encountering. I do click on "I can't
> install a local printer" but thats talking about stuff that happens
> after clicking on the "add a printer" button. Hope to hear from you
> soon.
> Thanks, Mark
> Queb--
> Queb-
