Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I asked some poeple i know. Some say it maybe a specified module might not be found? I don't know if that helps but hopefully you can find a solution.
Queb Wrote: > Ok, i downloaded the CJ2012SE driver from the Lexmark website. I unzip > it to a folder. I look at the readme file and says Lexmark System > Driver
> Date: August 7, 2001
> Please close all applications before installing the driver.
> This driver can only be installed through the Windows Add Printer > Wizard.
> Click UNZIP on the next screen to extract the driver files.
> Choose OK to continue with the Self-Extraction Program...
> The problem is that I can't enter the Windows Add Printer Wizard. The > add printer button still doesn't work, so in order to install this > driver it seems like i have to get that button working.
Use the original installation CD that came with the printer. Do not plug the
printer in until told to do so. When it asks you to plug it in you can
redirect
it to the newly download driver to install. Right now you'll need to
uninstall
what you've done.
Uninstall & reinstall Printer
http://www.coribright.com/windows/Article%20One.htm --
XP-WNP
Today is the first day of the
rest of your life.
> solution.
> > Driver
> > Wizard.
> Queb
