thats <A HREF="http://www.athlonxp.com/modules.php?op=modload&name=Diner_Wrapper&file=index&req=ShowFile&file_wrap=html/reviews_BaDass.html" target="_new">one hell of a case..</A>
That is WAY too much.. LMAO.. I think I would be in devorce court before I could complete a task like that. Some one had WAY toomuch time on their hands. It is cool though. Take care.
Left "Head": AMD1200, GF4 and chipset watercooled. 4 disks, DVD-Player, LS120, LEDmeter on the top.
Right "Head": AMD 450, TNT2, all passive cooled with an self designed air tunnel system. LEDmeter on the top. This board is mounted back to back with the other board.
"Intake": 8 air intakes (fake) and a self designed reservoir. Under the coverplate is a 5 port switch.
The fan is from an 1957 DKW-MUNGA (my old German Army Jeep) Behind the fan, (which turns at 60rpm) is a radiator (Cu).
At the bottom of the front is the control panel with 3 gauges from my 1969 Lotus Europe. The left gauge shows the tmep of the right air tunnel system, the other ones are showing the voltage of the 2 PSUs.
In the bottom is a digital recorder with a hot startsound and a little amplifier, which boosts the sound up to a good level. The sidepipes are from a motorbike.
