Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > help!! can't add a network printer
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
When I try to add a network printer, I get the error message "windows cannot
connect to the printer. Operation could not be completed." I used the
"connect to this printer" option, typing "\\192.168.x.xxx\printersharename",
also tried typing the computer name instead of IP address, same error
message.
I have no problem pinging the computer in question, nor accessing its
files. No problem adding a different network printer attached to a different
computer, either. I'm using a router with wireless access point.
I have read just about every thread in this and the Wireless sections,
without success. Please, somebody help!
Sponsored Links
For anyone out there who might be enduring the same problem, I finally solved
(at least, right now it's solved) my problem as follows, in this order:
first installed SP2 on the only unit still running SP1; I blew away all
network connections (wired and wireless) and the local network; I then began
from scratch to create new wired & wireless connections on each unit, and
finally reran the Network Setup Wizard on each unit.
message.
different
Reply to Anonymous
Is the PC with the printer on a dynamic or static IP address?
Cari (MS-MVP)
Printing & Imaging
"Ro" <ro@discussions.microsoft.com> wrote in message
news:C482C886-7DF8-4995-8A15-0B2FEEC3821F@microsoft.com...
> cannot
> message.
> different
Reply to Anonymous
very that net view \\computername returns the printersharename with type
Print
D:\>net view \\ntprint
Shared resources at \\ntprint
Server 2003 SP1
Share name Type Used as Comment
24_2046 Print 1200dpi
24_corp0047 Print HP LaserJet 8100
24_corp0056 Print HP LaserJet 8100
24_CORP0078 Print HP 5Si
24_CORP0085 Print HP 5Si
26B-1011-A Print DCA# 1150807 - Bldg 26, rm 1011
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
cannot
> message.
different
Reply to Anonymous
- 0 +
I have similar problem after migrating to XP and installing SP2. These are
network printers with Fixed IP address the local printer is O K
> Cari (MS-MVP)
> Printing & Imaging
> > cannot
> > message.
> > different
Reply to joel
- 0 +
I just wanted to add notify of reply
> Cari (MS-MVP)
> Printing & Imaging
> > cannot
> > message.
> > different
Reply to joel
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
