OK, so my system isn't loud by some peoples standards, but it's loud enough to keep the better half annoyed. I replaced the cheapo coolermaster 60mm fan with a cheapo 80mm fan and adaptor on the heatsink (XP1800+). Whilst the temperature is now 46 degrees under load, I am happy with it cos its quiet! But now it's the GF4 TI 4400 thats the loudest part of my system.
My question is this:
After some research and ruling out the Zalman flower fan, I have decided to go down the road of watercooling the cpu and gpu. I have a lian li PC 60 case with 2x 80 intake fans. Could I reposition the HDD and remove the tray, and put the reservoir / radiator here? Would the Lian Li fans be sufficiant instead of a 120 fan job?
I tried overclocking before, but my system was too unstable, so I will try again once I get some suitable & quiet cooling.
Oh yeah, everything has to be positioned inside the case because I have two inquisitive cats, which could provoke some shocking results.
Any recommendations / links / experience would be appreciated.
