Hi,
What is a good thermal solution (heatsink+fan) for an AMD XP2200+?
Secondly, what should the maximum weight of the heatsink be (so the MoBo doesn't snap!)
Thanks in advance,
VT
<P ID="edit"><FONT SIZE=-1><EM>Edited by vkov_tinsky on 12/01/02 03:17 PM.</EM></FONT></P>
IIRC the weight of the cooler should be below 300g, at least for ones that hold on using only 2 clips. Heatsinks that use all 6 clips regularly take more.
<b>Just because someone's a member of an ethnic minority doesn't mean they're not a nasty small-minded little jerk. <i>Terry Pratchett</i></b>
as pooba says, the stock fan (retail) does a good job. If you want something better or if you want some overclocking I would suggest you the Volcano 9: it has 6 clips and the smartfan included.
Volcano 7 is too loud and no better than Volcano 9.
Volcano 7+: is a good one but it doesn't have the smartfan, is too heavy (about 500 gr with the fan) and has ONLY 2 CLIPS (very riscky for that weight IMO)
<b>(<font color=yellow>as good as it looks</font color=yellow> )</b>
