G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi all,
I am sorry if my question is not suitable to be posted here.
My system is WIN2000 and with one modem card (ESS SuperLink-M
Data Fax modem) equipped inside. I use this modem with Winfax to send
faxes successfully for many years. Recently, I just can not use this
modem card to send out faxes nor to dial out. I delete it this device
and re-install again. It appears successfully and properly installed in
the COM3 of my system. I tested from Winfax and it said "FAX/modem is
class 1 compatible", in other word it is in good order, too. However,
when I use it to send out fax or proceed phone dialing, I can hear the
speaker is on with noisy signal sound as usual from Winfax or Phone
dialing program, but it just can not be connected to the line and gone
through successfully.
Is there any other way for me to check where is the problem? Please
help.
Lee
G
Guest
Guest
Turn the computer off. Disconnect the fax card from the phone wall jack.
Plug a standard Telco set into the female jack. Dial a number in the usual
way to confirm proper operation of the line. If OK., unplug the Telco set,
plug the fax card line in again. Check the plug/jack on the computer end.
You might change out the cable with a new or known-good cable. Turn the
computer on. When fully started, try using the fax again.
Let us know.
Tom
MSMVP
Windows Shell/User
<jk2435@ms1.hinet.net> wrote in message
news:1125645140.571632.213090@g43g2000cwa.googlegroups.com...
: Hi all,
: I am sorry if my question is not suitable to be posted here.
: My system is WIN2000 and with one modem card (ESS SuperLink-M
: Data Fax modem) equipped inside. I use this modem with Winfax to send
: faxes successfully for many years. Recently, I just can not use this
: modem card to send out faxes nor to dial out. I delete it this device
: and re-install again. It appears successfully and properly installed in
: the COM3 of my system. I tested from Winfax and it said "FAX/modem is
: class 1 compatible", in other word it is in good order, too. However,
: when I use it to send out fax or proceed phone dialing, I can hear the
: speaker is on with noisy signal sound as usual from Winfax or Phone
: dialing program, but it just can not be connected to the line and gone
: through successfully.
: Is there any other way for me to check where is the problem? Please
: help.
: Lee
G
Guest
Guest
I am sorry to bother you again. But I don't know what is Telco set
Please instruct.
> Let us know.
> Tom
> MSMVP
> Windows Shell/User
> : Hi all,
> : help.
> : Lee
G
Guest
Guest
news:1125884951.308615.213290@g49g2000cwa.googlegroups.com...
> Please instruct.
A regular voice telephone.
Earl F. Parrish
