I have a ASUS P4PE installed into a case which has front panel audio (FPA). If I remove the jumpers from the FPA hearder and connect up the case front audio connectors, the FPA connectors work fine, but I lost the sound from the rear on board connectors. Does anybody know a way that I could hook up the FPA connectors without affecting the rear on-board outputs? Any help would be appreciated.
