Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Printer Sharing Problem - XP Home SP2 and 98 SE
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Network configuration
Small LAN with multiple users:
Server : Windows 2000 Server
Clients : 2 Windows 98, 2 Windows ME, several Windows XP Home (SP1),
(New Install) Windows XP Home SP2
All File sharing and printer sharing (including shares on server and
between clients, e.g. XP (SP1) -> Me, ME->98...etc).
Understand windows XP home didn't got domain join ability. Know that
SP2 is quite annoying and so most of SP1 machines didn't got the
upgrade.
However, newly installed machines are all eqipped with Windows XP Home
XP2, problem occurs when communcating with sharing resources in Windows
98.
Symtons:
File sharing -> OKAY
net use, net view, start \\windows98machine -> OKAY
access share printer installed in windows XP home SP2 machine from an
windows 98 machine -> can see the printer but very slow connection (new
sometime to connect), during printing, the transfer speed is very slow
-> hence very slow printing speed. Other OS OKAY.
access share printer installed in windows 98SE
from windows xp home SP2 -> can see the printer, connect and
installation
okay, but during selection from the printer drop down box (say, in MS
Word), very slow responding and even no respsond, need to wait until
time out (>10s), can connect and print 1 times out of 3 trials.
Other OS all OKAY.
Have tried to disable firewall or make sure the "file and printer share
service" are enabled in the firewall exception, both not working. They
are all in the same work group already.
I believe it's a compatibility issue, are there any resolution or it's
an known problem?
Thanks in advnce.
Sponsored Links
There are 1083 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
