Are you talking about splicing a CPU cooler into the refrigeration lines? If you don't know anything about refrigeration systems, then this is likely going to be an impossible job, or it won't work very well at all.
I assume you know there is a special gas inside the lines. If you cut the refrigerator pipeline to install your cooler, the gas will blow out and the refrigerator will no longer work.
Consumer fridges are not meant to be serviced. Most are factory sealed, and do not have fill valves but instead have the fill lines soldered shut. If it breaks, you are normally supposed to just throw it away and buy another.
In order to splice in a cooler block, you'd have to replace the evaporator section with your cpu block. If you have no idea what the evaporator even is, stop now.
Next you'd have to scavenge moisture out of the lines. In the process of modifying the evaporator section, moisture will no doubt migrate into the lines as you are installing your CPU block. Moisture in the lines is Very Bad, and can cause total compressor failure if it freezes into crystals inside the suction portion of the compressor.
Purging moisture usually involves an inert "dry" gas like bottled nitrogen, blowing it through the lines and compressor to evaporate any moisture, then venting it out the high-side of the line.
Once purged, you draw the system down with a high vacuum to remove as much nitrogen as possible, and then "charge" the system with fresh refrigerant. You not only need to use the right kind of refrigerant, but also the right amount of a compatible lubricant.
If you fill the system without any oil, the compressor will fail fairly quickly. If you fill it with the wrong oil, it may not get along with the oil that was already in the system and form slime that can damage the compressor or plug up the lines.
All of this is probably way out of the range for a person without a degree in a Heating/Ventilation/Air-Conditioning (HVAC) program, and indeed most of the guages and refrigerants can't be sold to you unless you're licensed to do HVAC work.
Merely cutting open refrigerant lines also happens to be illegal at this point due to the ozone-depletion concerns of Refrigerant-12 (R-12). If you are to do this project legally, you are required to use a refrigerant scavenging rig to recover the refrigerant for recycling. Only then can you move on to modifying the refrigerator to be used with your project.
Scavengers cost a minimum of $3000, and you can probably score a HVAC license by first getting a 2yr Associate degree from a nearby tech college... so as you can see this is adding up to be a really expensive and time consuming little project..
