Archived from groups: alt.sys.pc-clone.compaq (More info?)
I have 2 Compaq Presario 2710US laptops, both with the same symptom.
When I power on, the fans kick on high speed almost immediately (well
before windows loads) then the system shuts off. I'm guessing heat
problems, both systems have been cleaned with pressurized air. I
contacted Compaq but they were little help. I've tried running linux
from a CD, no luck. I've updated the BIOS, no luck. Any ideas?
I know some Presario notebooks were shipped without the proper thermal
compound between the processor and heatsink. Have you checked that there is
thermal compound between them?
HH
"Jay" <JEOLeary@gmail.com> wrote in message
news:1112208568.704212.293600@z14g2000cwz.googlegroups.com...
The 2700's are well known for the hold down lugs coming loose from the
systemboard. These fasten the Fan and heatsink to the CPU and thats
generally why the high fan at startup occurs. It requires resoldering
the lugs and some disassembly. Weve done a ton of these and if you
need help just yell.
www.ikenfixit.com
Yes we do have a repair for the issue and it should be permanent..
Requires replacing the holddowns or lugs w/standoffs and they have
been doing fine as of yet. Glad to help if we can.. Ken
